LX176 38" snowthrower - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 36 Old 12-22-2009, 07:22 AM
tiny tractor big interest
Re: LX176 38" snowthrower
Originally Posted by Estreet View Post
That did it, thanks.
That's what we are here for. Glad to help.
Adam
lx176mainer is offline
post #17 of 36 Old 01-13-2010, 08:46 PM
kp647's Avatar
hello , I am a newbie here and have the same deal mo2462 38" going on an LX188, can one of you post a close pic of the way the front mount attaches to the frame?
or email to kp647@yahoo.com
thank you in advance
Kevin
kp647 is offline
post #18 of 36 Old 01-13-2010, 10:02 PM
I would but I am no longer using the factory setup as I am no utilizing a actuator as the means of lift.
Adam
post #19 of 36 Old 01-14-2010, 08:46 AM
kp647's Avatar
thanks for the response it seems the blower just hangs by the 2 j shaped bolts at the front ( along with the sway bar)
then at the back it hooks to the pins .(ordered those)
does that sound right?
kp647 is offline
post #20 of 36 Old 01-14-2010, 09:18 AM
kp647's Avatar
One other question, my JD dealer has been very helpful but has not been able to identify the bracket that the sway bar hooks into
does anyone know the part # , description or something that would help me figure that one out
thanks again
Kevin
kp647 is offline
post #21 of 36 Old 01-14-2010, 10:56 AM
Yeah what you said sounds perfect. My j bars thingies actually went into the square holes....made them perfectly straight vertically, but they are adjustable so should work in a variety of places. The part you need is 29 (M96016) on this diagram.
2 of each of 30 and 31 will make install a breeze or you can come up with two of your own nuts and bolts.
Adam
post #22 of 36 Old 01-14-2010, 01:55 PM
kp647's Avatar
That was a great help thank you!!
I will post some pics of my LX188 with the blower mounted next week!
thank you!
kp647 is offline
post #23 of 36 Old 01-14-2010, 02:18 PM
Your welcome....I will enjoy the pics when the arrive.
Adam
post #24 of 36 Old 01-16-2010, 02:38 PM
kp647's Avatar
Ok its nearly ready, picked up and installed the pins for the rear mount.
got the blower installed and the belt properly.
still need the sway bar bracket (jd dealer said monday)
ran it up , still need to adjust the spot on the lift arm that the rod that lifts the blower connects.
wondering if anyone has an opinion if the chute angle control cable is necessary, the whole blower only cost about $150 so far, and the dealer says the chute control cable is $100
kp647 is offline
post #25 of 36 Old 01-16-2010, 10:43 PM
Should be able to get by without it. For the most part you will find that full up is where it will like to be. I guess it depends on the areas you have to throw the snow to. I would at least give it a few storms to see if you even need to move the chute height at all from on initial setting.
Adam
post #26 of 36 Old 01-16-2010, 10:53 PM
gt275's Avatar
IMO, the chute adjustment is necessary if you don't want snow blowing back in your face. My current set-up, a 42" blower has the cable already, but my previous 38" blower did not. I bought the cable for $80 from the dealer for that one. You can also get an electric linear actuator to adjust the chute height. There are a few threads on that if you do a search you will find some info. I may end up doing that someday down the road.
BTW, looking at your picture, you need to raise the attachment point of the lift rod on the lever. It's about 4-6 inches too low from what I can tell.
2004 X485 (4/15) 25hp Kawasaki, 62" deck, 45 Loader, Front-mount de-thatcher.
2005 GX345 (11/09 w/124hrs) 20hp V-twin liquid cooled Kawasaki, 54" deck, Differential lock, Femco Cab Weather Enclosure, 42" snowblower, Electric Spout Rotation Kit.
Deere 10P poly Cart
-SOLD-
2001 345 20hp V-twin liquid cooled Kawasaki, 54" deck
1998 GT275 17hp Kawasaki, 48" deck, Cab Enclosure, 38" Snowthrower, Manual Spout Kit
1997 LX188 17hp Kawasaki, 48" deck
gt275 is online now
post #27 of 36 Old 01-17-2010, 10:18 AM
kp647's Avatar
I will adjust it when I get my say bar bracket installed
maybe wait til the first snow before i decide on the cable
will also have to see how much the chute blocks the headlighs and if aux headlight is necessary ( seems like i am always out at night)
also this summer I will sand and paint the worn areas inside of the blower so its nice and slick
Kevin
kp647 is offline
post #28 of 36 Old 01-22-2010, 06:23 PM
kp647's Avatar
well the sway bar bracket is installed , but i still dont have things adjusted to where the blower will stay in the up position
not sure what to adjust
Kevin
kp647 is offline
post #29 of 36 Old 01-22-2010, 09:27 PM
Certified Master Tinkerer
Herd of Deeres's Avatar
Kevin
Where is your mower deck height knob set? Try it all the way up (4") and see if that makes a difference.
Herd of Deeres is offline
post #30 of 36 Old 01-22-2010, 10:49 PM
gt275's Avatar
The mower deck height knob has nothing to do with the snow blower height. There is nothing to adjust to get the blower to stay in the up position. The handle should lock in the up position when it is pulled all the way back. The same way when you lift the deck and it locks into position. The rod that is connected to the blower should be attached high enough on the handle to lift the blower and keep the blower in the up position. I've had the same 38" blower as you have for over 13 years and that is how it works.
Deere 10P poly Cart
-SOLD-
gt275 is online now
