Some of my homemade contraptions - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 20 Old 04-15-2009, 12:30 PM Thread Starter
JGANDEE's Avatar
hey guys, I really like reading this section of MTF and gathering info for future projects. Below is some pics of projects I have built over the years.
This spring I built this sleeve hitch and modified an old tiller for the garden. It still needs some fine tuning but works well.
A couple years ago a friend and I built this pull behind mower. Its 48" cut with a 12hp briggs. I pull it with a DGS6500 Craftsman 54" cut. Together they laydown around 100" per pass.
I needed a new wood stove for the garage a while back and built this one out of 24" dia pipe. It is not much to look at but you dont have to squat down to load it and a trap door dumps the ashes into a 5 gal bucket.
My driveway is pretty long and the gravels tend to wash out from time to time. so I built this drag out of 8" beams. Its very simple but works really well. I need to install an electric winch on the pig pole so i dont have to get out to raise the drag for backing up.
JGANDEE is offline
post #2 of 20 Old 04-15-2009, 12:38 PM
Chuck_050382's Avatar
Re: Some of my homemade contraptions
that stove is awesome. I like your use of a grinding wheel as a knob, or is that the draft control?
I plan on mount a old tiller to my sleeve hitch like you have. Good job.
that drag looks like it should get it done.
Thanks for sharing your work.
Ford LGT 145, 2003 Craftsman GT 5000, 1977 MTD 990, 1983 Ford LGT 165, 1988 Cub Cadet 1210
Chuck_050382 is offline
post #3 of 20 Old 04-15-2009, 12:40 PM
DRIFTGOD187's Avatar
Images: 14
nice work
MY 111 & LT155
"The truck's a ford and the tractor's green" - Jason Michael Carroll
DRIFTGOD187 is offline
post #4 of 20 Old 04-15-2009, 12:47 PM Thread Starter
JGANDEE's Avatar
thanks, and yes that grinding wheel is the draft. It works good and does not get too hot to touch.
JGANDEE is offline
post #5 of 20 Old 04-15-2009, 12:53 PM
Retired Aug.31 2007
jeepersmitty's Avatar
I also like the stove. Good job on all.
I always know...
jeepersmitty is offline
post #6 of 20 Old 04-15-2009, 12:59 PM
Grateful11's Avatar
I wish I had that kind of ambition left in me. Reminds of my younger days. Thanks for sharing.
'11 John Deere 5065M /cab
'10 Kubota L3940 w/FEL
'09 JD X720
'91 CaseIH 5140 Maxxum w/cab
'78 IH 686 w/M&W Turbo 106 PTO hp w/canopy
Grateful11 is offline
post #7 of 20 Old 04-15-2009, 01:03 PM
Imagine it. Build it.
tiretrx's Avatar
Images: 8
Very ingenious, cost-effective and well-made. I like the way you think and do things dude!
.....just call me Ellis
I was abandoned as an infant and raised by a family of opposums........does that explain things?
tiretrx is offline
post #8 of 20 Old 04-15-2009, 01:08 PM
Handyman
Dragon's Avatar
Love the wood burner. Given the over all shape you could add some fins to the upper area where it transitions to the chimney. It would then look like an old aerial bomb and the fins would also radiate heat.
The drag is pretty slick. Did you make the derrick for it too or was that off of something else?
Dragon is offline
post #9 of 20 Old 04-15-2009, 01:16 PM Thread Starter
JGANDEE's Avatar
thanks, and that is a good idea about the fins. My friends call it the missle. haha! I built that derrick out of an old bent piece of pipe i found on a job. Its a big help. it slides into my reese hitch reciever.
JGANDEE is offline
post #10 of 20 Old 04-15-2009, 02:14 PM
Great thread!...I love the homemade contraptions part of MTF ,its a favorite of mine,since I cobb a lot of things together out of leftovers and scrap too!..
I like the stove,reminds me of one I made from 275 gallon oil tank,my friends called it "the moose" because I had a "T" and two pipes like truck stacks for the exhaust on it--looked like a big brown moose out in the yard when I'd use it to burn brush--I had it on wheels so I could tow it around with my tractor,used it in the garage and outside!..
I see a neat quonset building in the background of the derrick photo!..any info on that,I dont think I've seen one quite like that with the ribs on the siding going horizontal before..I have a home made wrecker unit that bolts in a truck bed similar to your derrick too!..
Tractor-Holic is offline
post #11 of 20 Old 04-15-2009, 02:36 PM Thread Starter
JGANDEE's Avatar
The moose, sounds pretty cool. I would love to see a pic of that, 275 gal is huge! My quonset building I got used and am not sure where is orginally came from. I really need to get some paint on that thing this summer.
JGANDEE is offline
post #12 of 20 Old 04-15-2009, 04:54 PM
I LOVE Garden Tractors!!!
MADD Man's Avatar
Nice work. I really like the stove as well, must keep you toasty in the cold months. Thanks for posting.
Mike
Looking for:
Hi/Lo pulley kit for a 64/65' Broadmoor
The winning powerball numbers
The pot of gold at the end of the rainbow
MADD Man is offline
post #13 of 20 Old 04-15-2009, 08:20 PM
Olratlr's Avatar
You have done well. Thanks for the post.
Olratlr is offline
post #14 of 20 Old 04-15-2009, 08:34 PM
The Magnificent
D-Dogg's Avatar
You are quite the fabricator! You should be proud. Thanks for sharing.
D-Dogg is offline
post #15 of 20 Old 04-16-2009, 11:04 PM
gwiz's Avatar
Nice job on all of your stuff. That stove must have taken some planning. And work. I see you took the pipe and cut out V's to get the taper at both ends. Nice work. It looks like a stove that if you had to buy it you could never afford it. Not having to squat down is a real benifit.
Lawn Boy 7022
Lawn Boy 7271AE
Lawn Boy 7260C
Lawn Boy 10201
3hp Briggs engined mish-mash
21" Murray w/ Briggs
gwiz is offline
