18hp twin log splitter - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 11-16-2011, 10:07 PM Thread Starter
Derfla's Avatar
built a log splitter for a buddy. twin 18hp briggs for the engine. 13.6 3200 psi for the pump. and a 4.5 in trunnion mount cylinder. 8 in H beam chevy caviler axle. fabricated tank to match size of beam.
Name:	2011-09-02 14.45.06.jpg
Name:	2011-08-23 20.28.39.jpg
Name:	2011-08-25 10.09.50.jpg
Name:	2011-08-25 19.11.20.jpg
Derfla is offline
post #2 of 13 Old 11-16-2011, 10:08 PM Thread Starter
Derfla's Avatar
Re: 18hp twin log splitter
more pictures
Name:	2011-08-25 19.11.35.jpg
Name:	2011-08-27 12.20.40.jpg
Name:	2011-09-02 14.45.49.jpg
Name:	2011-09-07 20.35.12.jpg
Derfla is offline
post #3 of 13 Old 11-16-2011, 10:09 PM Thread Starter
Derfla's Avatar
and some more
Name:	2011-09-07 20.35.44.jpg
Name:	2011-09-07 20.36.05.jpg
Name:	2011-09-07 20.36.20.jpg
Name:	2011-09-30 17.29.10.jpg
Derfla is offline
post #4 of 13 Old 11-16-2011, 10:11 PM Thread Starter
Derfla's Avatar
finished.. now if i ever get my little loader done.
Name:	2011-10-04 15.49.08.jpg
Name:	2011-10-23 16.59.51.jpg
Derfla is offline
post #5 of 13 Old 11-17-2011, 04:05 AM
15,000+ Posts & Climbing
That's a nice 25 ton splitter. It should stand up well and turn a lot of big wood into little wood.
Is you buddy on the firewood business, or is just for his own use?
TUDOR is online now
post #6 of 13 Old 11-17-2011, 10:24 AM
speakerman0320's Avatar
Images: 29
Now that should be a get-urr-done machine.
speakerman0320 is offline
post #7 of 13 Old 11-19-2011, 03:38 PM Thread Starter
Derfla's Avatar
just his own use. 18 hp was way over kill but on the bright side u can split at an idle.
Derfla is offline
post #8 of 13 Old 11-19-2011, 05:03 PM
Not necessarily. I had a Huss "Honest Abe" 24 ton splitter (1980) that was 16 HP. It wore out two cast iron Briggs engines and was into its third engine (a V-twin Vanguard) when I sold it.
rscurtis is offline
post #9 of 13 Old 11-20-2011, 03:54 AM
How many hours did you put on the engines? I've split a tandem load of maple and birch logs (25 face cords) in about 16 hours working alone with my 7.5 ton homebuilt splitter running off of my loader hydraulics on my MF1655 and rarely used more than 2/3 throttle.
Splitting wood is a lot less work for an engine than snowblowing. It's quite literally only occassionally a few seconds per minute at maximum load with a well designed hydraulic system.
TUDOR is online now
post #10 of 13 Old 11-20-2011, 10:23 AM
GANG GREEN GIZMOW KILLER!
RaisedByWolves's Avatar
Yeah, I would say something in that system was not right.
I have a Cheapie 20 ton splitter with only a 5hp briggs pos engine that has seen much use between our hunting cabin, my last house (2 cord/year) My current house (4 cord/year) My brother and neighbor who each do about a cord a year.
It is about 12yrs old and admittedly it is getting a bit wheezy, but it still runs.
I also never really go much past 2/3 throttle.
http://jd318techforum.proboards.com/index.cgi
http://houseofhomelite.proboards.com/index.cgi?
POWERKING "79" 2416
ECONOMY "64" JD
KUBOTA 4200
"68" JD 140 H-3
And a restored JD318
RaisedByWolves is offline
post #11 of 13 Old 11-20-2011, 10:44 AM
Ken in NJ's Avatar
Nice job on the splitter
Mine is set up sorta like your with the ram sliding on the beam. After 35 years (Guess) I just had to rebuild the slide from wear, the grit and dirt made it loose as a goose over the years and it started to twist off the bed when splitting twisted stuff.. and that caused the cylinder seal to start leaking.
Now its better then new, and adjustable for when it wears down again.
Ken in NJ is offline
post #12 of 13 Old 11-20-2011, 10:48 AM
What I didn't say is that the machine was used in rental service from 1980 until 2006, when I sold it (for $1300). Only the third engine had an hourmeter on it. I would estimate it had multiple thousands of hours of use, and it wasn't anywhere near its fatigue life. That splitter will still last someone another lifetime.
rscurtis is offline
post #13 of 13 Old 11-20-2011, 02:23 PM
Ahh! "The rest of the story!"
Not a poor system, just lots of work.
TUDOR is online now
