My Tractor Build - Page 3 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #31 of 87 Old 11-23-2011, 04:30 AM
15,000+ Posts & Climbing
Re: My Tractor Build
My MF1655 weighs in a little over 2400 with me in the saddle. I've stood it on the front tires alone when pulling 10" dia., 4.5' long concrete posts out of the ground. That's over 4000 lb on the 1" spindles.
There aren't too many GT's with 3/4" spindles that you can ballast to that level. With my old MF12H, I could only get up to 1350 with the same FEL on it. It would stand on the front wheels with an 850 lb payload for 2200 lb on the spindles. I put over 100 hours a year for 7 years on that tractor, likewise for 22 years with the 1655. Almost all loader work.
Never hurt the spindles on either tractor, and never hurt the axle on the MF12H.
The weak point is the axle pivot. That's where all that weight interacts with the frame.
TUDOR is online now
post #32 of 87 Old 11-23-2011, 12:23 PM Thread Starter
CrazyRoper's Avatar
That sounds better, im pretty shure that gravely is a pretty heavy tractor, and my axle pivot is a 1" grade 8 bolt so there wont be any troubles there
tractors:
1980 Turf Trac 16/44 (MTD 824) - rear side-by-side plow, rear snow/dirt blade, v-bar 4 link tire chains.
1982 John Deere 66 RER
1988 Roper YT16 hydro
other:
2006 Craftsman Push 6.5hp front wheel drive
1983 Princess Auto Mini Bike (in progress)
1967 Mercury (ford) half ton 240 3spd
1965 snow cruiser 360 opposed twin, 2 stroke, 14hp
operator of:
2010 John Deere 2320 mid mower, bagger and rear tiller.
2005 Grasshopper 60" front mount , bagger
CrazyRoper is offline
post #33 of 87 Old 12-15-2011, 10:19 PM Thread Starter
CrazyRoper's Avatar
ok, it is motor time!! i have 3 choices.
1. go to princess auto and pick up a brand new 6.5HP motor (89.99)
2. spring for a new 13HP motor (250.00)
3. ask around and hope that some one has one for cheap.
4. ask my uncle very nicely if i can buy (or have) the 18 HP Opposed twin briggs sitting on the shelf of the storage building at the farm. (insert tim taylor growl here).
the only problem with the briggs is it may not fit as well as it should and im not shure how the dash would work.
opinions??
tractors:
other:
operator of:
post #34 of 87 Old 12-16-2011, 05:36 AM
Number 1 is a little light, even for the mountains in Manitoba. Number 2 is a much better option.
Numbers 3 and 4 are the preferred choices, although availability on a timely basis is suspect and space considerations must not be taken lightly.
Give it some time for something to show up and then go with #2 if necessary.
The prices for those engines must be in the showroom. They sure aren't in the catalogue.
TUDOR is online now
post #35 of 87 Old 12-16-2011, 09:12 PM Thread Starter
CrazyRoper's Avatar
thanks, the prices are on the website, and they are both powerfist engines.
if the 18 hp fits good would it be the best choice??
tractors:
other:
operator of:
post #36 of 87 Old 12-17-2011, 08:07 AM
Not necessarily. Horses are hungry and you don't really need that many for loader work. The first engine that you mentioned will "do" the job, but it won't like any kind of slope with the weight of a tractor set up for loader work. It will climb ramps onto a trailer, but it's going to complain.
The big Briggs won't complain about anything, but those extra cubic inches will want to be fed. My 12 hp Massey had adequate power and wasn't all that thirsty. My 20 hp MF1655 thinks I own an oil well in comparison.
The bottom line is big horsepower is for powered implements and hill climbing. GT's in general simply don't have the weight to use more than 10 or 12 hp when working on flat ground with a FEL, and that includes my 2400 lb 1655.
That being said, if you intend to play in the wet ground with any frequency, definitely get the Briggs. I know what Saskatchewan gumbo is like and I assume Manitoba's is similar. I make every effort to keep my tractors out of the mud. I learned my lesson the first spring that I had my 1655, 30 years ago.
TUDOR is online now
post #37 of 87 Old 12-17-2011, 09:00 AM
MrGiggles's Avatar
Images: 10
Briggs opposed twin with dual stacks.
I'm 18 and still think this is cool.
Mowers:
2005 Troy Bilt ZTR 42-19hp Briggs I/C 42" Deck
Chainsaws:
Husqvarna 50 Special, 20" and 16" bars
Stihl 066, 25" and 20" bars
Jonsered 2252 Autotune, 18" bar
Craftsman 2.1
Other:
Stihl FS90R with Brush Blade
1999 Kawasaki Bayou 220 ATV
Collection still growing.
MrGiggles is offline
post #38 of 87 Old 12-17-2011, 09:38 AM
Onan18's Avatar
You might want to consider finding something with pressure lube, like a Kohler Magnum Twin, Kohler Command, or an Onan.
Joe
Onan18 is offline
post #39 of 87 Old 12-17-2011, 09:42 AM Thread Starter
CrazyRoper's Avatar
Thumbs up Re: My Tractor Build
the thing with my tractor is FEL work will not be its primary duty, it is going to be in the garden alot too, plowing and such,
so im thinking that if i can get this 18 from my uncle cheap or free, it would be my best choice.
if he doesnt want to sell it then i will take a cruise over to Princess Auto and pick up the 13HP
tractors:
other:
operator of:
post #40 of 87 Old 12-17-2011, 03:47 PM
Sounds like a good plan to me. Too much horse power is better than not enough and budgets rule the world.
TUDOR is online now
post #41 of 87 Old 12-17-2011, 04:01 PM
Yup! They look cool .................... right up to the point where you have to tarp up the tractor to protect it from the 60 mph breeze blowing across a flat prairie and carrying a foot of snow with it. If the tarp stays put, the stacks will poke holes in it.
Not everyone can park their tractor inside.
TUDOR is online now
post #42 of 87 Old 01-23-2012, 07:34 PM Thread Starter
CrazyRoper's Avatar
ok boys, im back at it and got a motor picked out, its the 16HP Briggs i rebuilt, it came out of the same tractor as the rear end. the only problem is it is a vertical shaft and my trans has a horizontal shaft so i am going to have to to use a stupid twisted belt clutch system, but i think it should be ok
tractors:
other:
operator of:
post #43 of 87 Old 11-03-2012, 11:17 PM Thread Starter
CrazyRoper's Avatar
Long time since I have posted an update. I have totally revamped my plans for this stupid thing.i now have a vw 1.6 nc diesel motor and 5 speed trans, and a ford 7.5 rear axle. I will possibly be making it articulate and 4x4 but we will see about that one...
tractors:
other:
operator of:
post #44 of 87 Old 11-04-2012, 08:00 AM
biker's Avatar
Boy did you change your plans. Keep posting pictures!!!
John Deere 750
Kubota B6200
Craftman GT5000
Building A Hydraulic Drive Homemade Tractor
Happy Wife Happy Life Sad Wife OOH No
Nothing But The Truth
biker is offline
post #45 of 87 Old 11-07-2012, 11:54 PM Thread Starter
CrazyRoper's Avatar
It's coming along...please mind the mess..lol I don't have a lot of garage room to work with.
On a side note I have decided on conventional solid axle 4x4 and I am hopefully going for the engine/trans on Saturday.
tractors:
other:
operator of:
