R/T tractor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 11-02-2010, 04:24 PM Thread Starter
Lindeman crawler fan
jdcrawler's Avatar
R/T tractor
While I'm waiting for the new gas tank for the Ridemaster cart to show up, I'm going to go back to work on the R/T tractor.
When I built the tractor, the rear axle turned out to have a 12 to 1 gear ratio and the rear tires are about 2 or 3 inch smaller diameter than the original tires.
I have used the tractor a little but the combination of the gear ratio and smaller tires makes it really slow.
About a month ago I was able to get a rear axle with the 5 to 1 gear ratio.
So I'm going to bring the tractor back in and swap out the rear axle.
I've also decided to take the front end loader off of it.
I have played with it a few times and it works just fine for what it is.
The problem is that I have been spoiled with the FEL on the Lindeman crawler.
The crawler weighs almost 6,000 pounds and has traction that is unquestionable.
It will go thru snow, mud and loose sand with out and problem.
The 1,500 pound tractor on rubber tires can't even compete with that.
So I said to myself: "Self, why are you carrying the bucket around all the time if you're never going to use it?"
Today I got the FEL off the tractor and took it out side and took some photos so I can put it up for sale.
Here's the tractor with the FEL removed and ready to start on switching the rear axle.
This is the other rear axle that I picked up.
Ray
1949 Agricat crawler
( 3 ) 1948 Bolens Ridemasters type #35AA01
1939 Viking / Standard Twin
1962 Panzer model T70
"R/T" home made tractor
jdcrawler is offline
post #2 of 9 Old 11-02-2010, 04:57 PM
evo803's Avatar
Re: R/T tractor
What about taking the bucket off and making some type of other attachment like a grapple , forks or something , seems a shame to pull it off and sell it after all that beautiful work you did. Don't make this decision hastily, you will wake up one night with a briiliant idea on how to customize it to make something you really need . Just my 2cents .
Chris
" Friends don't let friends drive stock ! "
evo803 is offline
post #3 of 9 Old 11-02-2010, 07:29 PM Thread Starter
jdcrawler's Avatar
Re: R/T tractor
I have a 4-wheel drive fork lift for anything that I need to move or lift.
My initial reason for building the tractor was for using the 3-point hitch inplements to maintain the drive and for towing a trailer around.
The FEL idea came along later as something that I thought I would use but I ended up still firing up the crawler to move dirt because it has more power and just works better.
Ray
post #4 of 9 Old 11-02-2010, 07:43 PM
Re: R/T tractor
Consider the times you may want to use a FEL around the yard. I've mentioned a couple of times my wife's reaction to my bringing a crawler into the front yard to remove a stump. Those rubber tires would be a lot gentler on grass and other landscaping.
Your machine and you know your needs way better than anyone else.
Mike
A gun and a parachute are much the same. When you need one nothing else will really suffice.
Tencubed is online now
post #5 of 9 Old 11-02-2010, 08:10 PM
Re: R/T tractor
Even though your FEL was well built and all, I preferred the look of your tractor without it.
You could always build a little 3pt bucket for the back for light duty stuff around the yard.
Dominqiue01149 is offline
post #6 of 9 Old 11-03-2010, 05:17 PM Thread Starter
jdcrawler's Avatar
Re: R/T tractor
Was able to get the tractor all stripped down today.
Ray
post #7 of 9 Old 11-10-2010, 12:00 PM
MTF New Poster
ben2go's Avatar
Re: R/T tractor
I dunno how I missed this one.OK now I am caught up.
ben2go is offline
post #8 of 9 Old 01-01-2011, 04:12 PM
123maxbars's Avatar
Re: R/T tractor
where did your new transaxle come from/what size tractor/make/model?
123maxbars is offline
post #9 of 9 Old 01-01-2011, 11:09 PM Thread Starter
jdcrawler's Avatar
Re: R/T tractor
The new rear axle is from a Economy Jim Dandy tractor the same as the original rear axle.
The only difference is the gear ratio is a 5/1 instead of a 12/1.
Ray
