John Deere 400 hydrostatic transmission ? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 10-03-2010, 07:30 PM Thread Starter
Mark Adams's Avatar
Hi All
Is there some one who could help me out.
I would like to use a John Deere 400 hydrostatic drive transmission on something that I am building. I see them on E-bay.
Most are run with a 20 hp.
#1 What is the rotation going into the hydra. drive? ( From the motor ) Is it C.W. ???
#2 What RPM's do the hydrostatic run at?
#3 There are 3 hose conections on the hydra. drive, what do they go to?
#4 Dose the oil in the rear end mix with the oil in the hydrostatic drive?
#5 This is a big one, If the speed going into the hydrostatic was 1000 RPM,s what would the RPM,s coming out be? What is the ratio?
Thank you for your help
Mark
Mark Adams is offline
post #2 of 4 Old 10-04-2010, 03:25 AM
15,000+ Posts & Climbing
Re: John Deere 400 hydrostatic transmission ?
Originally Posted by Mark Adams View Post
Hi All
Optional, depending on which end of the engine is driving it. Adjustment for rotation is done by turning the charge pump housing 180*.
Max is 4000. In GT's usually 3300 - 3600 RPM.
One line from the rear end to supply the hydro and 2 from the hydro for implement lift hydraulics.
The oil in the rear end is the oil for the hydro. The rear end is the reservoir.
1000 RPM. Ratio is 1:1. The reduction is all done in the rear end.
Mark
My information is specific to Sundstrand Series 15 hydro units. I'm pretty sure that it is accurate for comparable Eaton units as well.
TUDOR is online now
post #3 of 4 Old 10-04-2010, 11:29 AM
Eaton 11's are 2:1 for input/output.
One top port is intake from reservoir, second is to auxiliary hydraulics/filter/cooler, return from filter is to the side port, and finally the return to the reservoir is around the output shaft. Correct me if I'm wrong; just expecting that the OP is going to ask.
Chagrin is offline
post #4 of 4 Old 10-04-2010, 07:59 PM Thread Starter
Mark Adams's Avatar
Thank You Gentlemen.
I have used the #11 Eaton hydrostatic transmissions in the past and the ratio was 1.8 to 1.
The info that you have given me will help. I think that I will go with a Eaton and not the John Deere hydro..
I was thinking of changing the Eaton hydro. that I put in my tractor. Its real loud and heats up fast. I think that the hydro. has seen beter days.
I was thinking that I would try the John Deere hydro., but the ratio is the problem.
Thank again
Mark
