Backhoe hydraulic set-up? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 05-23-2010, 01:02 PM Thread Starter
Thinking of building a backhoe attachment for a Deere 425. What type of pump ,cylinders and valves should I use? Thinking of 2"-2 1/2" cylinders with 1" rods? Boom 14",Dipper 10",Bucket 12",Swing 7" and Stabilizers 8"? Don't have a clue on what spool control valve to use. Going to base my design between the Kwick-Way and Kyoker backhoes. Please give brands and models.
Thanks
cnchobbyrich is offline
post #2 of 5 Old 05-23-2010, 01:40 PM
simple simon's Avatar
Re: Backhoe hydraulic set-up?
Hi
Dosen't J.D. 425 have a Hydraulic system of it's own?
One pump is all you need.
Spool valves are a personal preferance. I like the twin joy sticks my self, But all I had was single levers.
S.S.
simple simon is offline
post #3 of 5 Old 05-24-2010, 08:10 AM Thread Starter
Originally Posted by simple simon View Post
Hi
S.S.
425 has a pump-hydrostatic drive, not sure if it would have enough power or flow
post #4 of 5 Old 05-24-2010, 11:01 PM
4.65 GPM, so it's pretty close to reasonable.
Chagrin is offline
post #5 of 5 Old 05-26-2010, 04:33 PM Thread Starter
Where do you connect into the on-board hydraulics?
At the slective control valve?I has to plugs.Would these be controled by the levers for the front and rear exsisting cylinders?
I want independent control of the backhoe,basicly a to pump, to tank type connections that a 4 spool valve can be used.
Also thought I could tee into the line between the rear axle -pump and the power sterring for the supply? Add a 4 way connection in place of the 3 way one (before radiator) for the return?
