John Deere 2320 Home made FORKS! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 29 Old 04-01-2010, 11:30 AM Thread Starter
fireballferkey's Avatar
Exclamation John Deere 2320 Home made FORKS!
Ok I looked into getting a set of jd forks for my 2320 but they wanted around $650-$1200 depending on what style and size I wanted... So I built my own bought the forks and top & bottom rails off ebay for $229 shipped to my door then purchased some steel from work and here ya go for a toltall of $272 dollars and 10 hours labor I now have a set of very light yet durrable quick attatch forks. 36". Just need to build a bolt on rack or gaurd and give it some green paint!
fireballferkey is offline
post #2 of 29 Old 04-01-2010, 11:33 AM
Imagine it. Build it.
tiretrx's Avatar
Images: 8
Re: John Deere 2320 Home made FORKS!
Very nice work. Nice design and clean work on the welding. Hats off!
.....just call me Ellis
I was abandoned as an infant and raised by a family of opposums........does that explain things?
tiretrx is online now
post #3 of 29 Old 04-01-2010, 11:41 AM
Lindeman crawler fan
jdcrawler's Avatar
That is an excellent job. They look very sturdy.
I really like the quick disconnect setup.
Ray
1949 Agricat crawler
( 3 ) 1948 Bolens Ridemasters type #35AA01
1939 Viking / Standard Twin
1962 Panzer model T70
"R/T" home made tractor
jdcrawler is online now
post #4 of 29 Old 04-01-2010, 11:54 AM
Looks great. You can lay down really nice beads. Thet should serve you well.
witco is offline
post #5 of 29 Old 04-01-2010, 01:52 PM
Joe NE Texas's Avatar
Images: 6
That looks good Nice work.
Joe NE Texas
Joe NE Texas is offline
post #6 of 29 Old 04-01-2010, 10:52 PM Thread Starter
Thumbs up Re: John Deere 2320 Home made FORKS!
Thanks guys it took a little time cutting the gussets out and getting them all trued up but was well worth it. I got to use the rig today to move around some railroad ties and a small pile of tree limbs seemed to work very well.
post #7 of 29 Old 04-02-2010, 01:36 PM
C F Industries's Avatar
That looks like it was factory made, you can tell that a lot of time was taken to fit and weld everything right. Very nice!
C F Industries is offline
post #8 of 29 Old 04-02-2010, 03:32 PM
Buckeye Hunter's Avatar
If that was all painted up, I'd have a hard time believing it was home made. Very good job.
2009 John Deere LA145 w/ 48" mower deck & custom trash bucket holder
1983 John Deere 111 w/ 42" snow plow, custom weight bracket, headlights, tail lights & strobe light
1983 John Deere 111 w/ 38" mower deck, 38" snow thrower, headlights, tail lights & strobe light.
Ariens RT5020 tiller
Universal 12.5 Poly Cart
Agri-fab 175 drop speader & 42" sweeper
Brinly-Hardy 40" dethatcher
"That's the great thing about a tractor. You can't really hear the phone ring."-Jeff Foxworthy
Buckeye Hunter is offline
post #9 of 29 Old 04-02-2010, 04:49 PM
Images: 10
Well done Fireball!!! I had 3pt mounts added to mine. I dont use it on the 3pt very much, but when I do its handy.
NEWT92 is offline
post #10 of 29 Old 04-09-2010, 05:36 PM Thread Starter
In two part epoxy primer now JD Green next week...
post #11 of 29 Old 04-11-2010, 07:22 PM
midnitetr8n's Avatar
Hey fireballferkey that is some great fab work on that set of forks. Do you know what class the forks are? I have been looking for set of inexpensive light duty forks, class I or II to use on a project.
Theo
Live Green or Die.
2008 JD-X500
JD 10P Cart, JD Integral Hitch, 40" Brinly Rear Blade, JBJR, 10" Brinly Moldboard Plow, 42" Brinly Lawn Sweeper, Brinly Cultivator, 1 Ton Winch
1984 & 1988 JD420
(Long Term Projects)
1988 JD332
1985 & 1988 JD318
3ph, #15 JD 3pt Moldboard Plow, 1 Ton Winch, Brinly 3pt Four Gang Disc Harrow, Brinly 3pt Cultivator w/ Hiller Discs, JD 54" 4 way Blade, 3pt Carry All, 4'-6' Telescoping Boom Pole, MCS
1972 & 1973 JD140 H3
Sleeve hitch, JD 54" 2 way Blade
1967 RF 112H
midnitetr8n is offline
post #12 of 29 Old 04-12-2010, 09:08 PM Thread Starter
class 2 here is the exact kit I purchased from the same seller http://cgi.ebay.com/NEW-36-PALLET-FO...item45f2242842 or if you just need the forks he has them too here they are.... http://cgi.ebay.com/NEW-36-PALLET-FO...item439e4dd495
post #13 of 29 Old 05-02-2010, 07:54 AM
ensoll's Avatar
Hello again FB,
Can you share what you bought for the JD quick attach pieces (JD part numbers)? I've been searching the parts site and can't seem to get results.
It seems I might be getting the opportunity to build a pair of these for myself, thanks to being born in this part of the year. Oh well, she asked what I wanted....
Chris
John Deere 2520
Worklight Horse Blinders, 200CX Loader, 49" & 61" buckets, Artillian Pallet Forks, 46 Backhoe,13" bucket, Artilillian Turf Feet, Brotek ripper & thumb, 47 Blower, 54 Plow, 413 Rotary Mower, 60" Woods landscape rake, 48" 3pt plug aerator, Ballast Box, Pat's Easy Change System
John Deere X324
48" deck, mulch kit, MC519 Cart, Deere 10P cart, off-brand cart
Lightweight Pallet Forks and Other Attachments for John Deere tractors
www.ARTILLIAN.com
ensoll is offline
post #14 of 29 Old 05-02-2010, 01:35 PM
evo803's Avatar
Awesome job , very professional looking. What process did you use to weld this project toghether and what brand is it ?
Chris
" Friends don't let friends drive stock ! "
evo803 is offline
post #15 of 29 Old 05-08-2010, 12:06 PM
Scott Hightower's Avatar
Nice job on the welding!!!!
You should consider marketing your design. I bet a few of the guys on here would be interested.
Scott
Fab Manager
http://www.welders360.com/
Scott Hightower is offline
