Building my tractor-14 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 15 Old 02-17-2010, 02:31 PM Thread Starter
Lindeman crawler fan
jdcrawler's Avatar
Links to previous post on this tractor.
Start Building a tractor
-1 Building a tractor-1
-2 Building a tractor-2
-3 Building my tractor-3
-4 Building my tractor-4
-5 Building my tractor-5
-6 Building my tractor-6
-7 http://www.mytractorforum.com/showth...388#post981388
-8 Building my tractor-8
-9 Building my tractor-9
-9/2 Building My tractor-9 ( part-2 )
-10 Building my tractor-10
-11 Building my tractor-11
-12 Building my tractor-12
-13 Building my tractor-13
This engine sat under the seat on the EzGo utility cart so the clutch pedal was in front of the engine.
The linkage from the clutch pedal pulled the clutch arm forward.
This is the original clutch lever arm on the engine.
The clutch pedal on the tractor is going to now be behind the engine so I need to change the clutch arm so it pulls backward.
First I cut the original clutch arm off.
Then I made a sleeve that fits over the clutch shaft. This sleeve has a 3/4 inch diameter shaft sticking out with a keyway milled into it.
Next, I made a new clutch arm that fits on the shaft.
This arm extends down along side the frame so when it is pulled backwards it opens the clutch.
For the clutch pedal pivot pin, I made a mounting plate from 5/8 inch thick steel.
A 1 inch diameter shaft is pressed into this plate and welded on the the back side.
This pivot pin is then bolted onto the side of the frame.
I found an old steel roller off something, that has bronze bushings with a 1 inch diameter bore.
This is going to be the base for the clutch pedal.
Because the steering is mounted on this side, I don't have as much room to work with as I did on the other side with the brakes.
This shows the clearance with the steering arm all the way back.
Also note, I welded a steel plug in the end of the foot pad support. There will be a brace from it to the pivot pin.
Here is the finished clutch pedal.
The pedal is mounted and the linkage is made between the clutch pedal and the clutch arm.
A plate is bolted on the end of the foot pad support and the end of the pivot pin.
This supports the end of the pin and keeps the clutch pedal from sliding off.
A view of the linkage from the top.
I tried to operate the clutch by hand with just the clutch arm and could not budge it.
The pedal works smoothly and is easy to operate even by hand.
Ray
1949 Agricat crawler
( 3 ) 1948 Bolens Ridemasters type #35AA01
1939 Viking / Standard Twin
1962 Panzer model T70
"R/T" home made tractor
jdcrawler is offline
post #2 of 15 Old 02-17-2010, 02:35 PM
Retired Aug.31 2007
jeepersmitty's Avatar
Re: Building my tractor-14
Looks great.
I always know...
jeepersmitty is offline
post #3 of 15 Old 02-17-2010, 03:50 PM
More quality work. Well thought out and executed.
Mike
Tencubed is offline
post #4 of 15 Old 02-17-2010, 06:10 PM
5000 posts and climbing
m.jodrey's Avatar
That looks just like a factory built tractor.No actually,I think it looks better.
Maynard
1963 Bolens 800,1972 Bolens 1256, 1972 Bolens 1886, 1973 Bolens H16, 1978 Massey 1655, 1961 Cub Cadet Original, 1979 Cadet 85, 1980 Cub Cadet 482, 1963 Gravely L, 1993 Ford 6640 4X4,2008 Kubota 2110 diesel,1970 Bolens 1053,2002 John Deere JE63S self propelled lawn mower
m.jodrey is offline
post #5 of 15 Old 02-17-2010, 07:36 PM
I'm quite impressed with all the webbings and gussets, They make the difference between something slapped together and a professional looking job.
rockinmywaypa is offline
post #6 of 15 Old 02-17-2010, 08:07 PM Thread Starter
jdcrawler's Avatar
I probably don't really need some of them that are there but in the long run they can make the difference in it lasting 5 years or 30 years before I have to repair something.
Ray
post #7 of 15 Old 02-17-2010, 08:12 PM
Out' standing!! I've been waiting to see what was next. Gettin tight in there ain't it?
old1mech is offline
post #8 of 15 Old 02-17-2010, 08:53 PM
Banned!
Ray , talk about vision. Your work is second to none, outstanding.
Thank you for sharing it. John
John@Reliable is offline
post #9 of 15 Old 02-18-2010, 12:05 AM
mikeemc's Avatar
nice job .love the welding work. Later on you may find out your toe kicks the gas tank pushing that pedal down after a full days work, may want to shorten up that leaver a little. rest your heal rather than lift for the push . just a thought
mikeemc is offline
post #10 of 15 Old 02-18-2010, 06:29 AM
Ironmower's Avatar
Great build, great post and great craftsmanship!! Thanks, can't wait to see it done.
Ironmower is offline
post #11 of 15 Old 02-18-2010, 12:09 PM
migraineman's Avatar
Images: 31
Fantastic. That clutch pedal is just sexy as ****. Top notch construction. Keep up the good work.
migraineman is offline
post #12 of 15 Old 02-18-2010, 12:58 PM Thread Starter
jdcrawler's Avatar
That's a good observation but the pedal isn't as close to the tank as the photos make it seam.
Here is a view from the seat. As you can see, the pedal sits to the outside of the tank and there is a lot of room between it and the tank.
I think it will be OK on clearance but that is just one of those things that I won't know for sure until I start driving it.
I can always change it later if I need to.
Ray
post #13 of 15 Old 02-18-2010, 01:43 PM
MTF New Poster
ben2go's Avatar
It's time.Time to venture out and start your own line of production garden tractors.
This is one great build.
ben2go is offline
post #14 of 15 Old 02-18-2010, 11:13 PM
C F Industries's Avatar
Wow J D I am very impressed with your fab work. I once made a clutch linkage for my 67 ranchero when I installed bronco running gear to make it 4 wheel drive. I had to remake the linkage 3 time before I designed something that would work and not bend or give me trouble . This looks professional. Great job
C F Industries is offline
post #15 of 15 Old 02-25-2010, 12:00 PM
Grand Sierra's Avatar
I won't me one of those. Nice work.
Grand Sierra is offline
