homebuilt mini skid steer - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 56 Old 01-30-2017, 12:28 AM Thread Starter
I posted in how you move your wood my mini skid steer if this is the right place i will try to post build story and photos
Name:	2016-12-15 13.57.07.jpg
gordonr is offline
post #2 of 56 Old 01-30-2017, 02:47 AM
15,000+ Posts & Climbing
Re: homebuilt mini skid steer
It's as good a place as any for where to post the story on that nifty little skid steer!
Should be a real good read from the looks of it!
TUDOR is offline
post #3 of 56 Old 01-30-2017, 09:33 AM
With as many pictures as you have of the build and more pictures of it doing what you built it for.
DonF
DonF is online now
post #4 of 56 Old 01-31-2017, 01:44 AM Thread Starter
Here is the start the 6 inch wide frame rails with 1/4 plate floor with channels for drive chain I used dodge caravan front drive hubs took the axle apart and welded on 24 tooth plate 60 pitch sprocket onto the axle stub shaft You can see frame and loader arms in position taking shape with hydraulic motor blocked up
ID:	1889242   Click image for larger version
ID:	1889250   Click image for larger version
gordonr is offline
post #5 of 56 Old 01-31-2017, 02:46 AM
4K and there's still more
Donewrken's Avatar
Awsome!
What a handy little item to have around the yard.
and I like the look of the shop, the wood & window, sort of homey.
Donewrken
Donewrken is offline
post #6 of 56 Old 02-01-2017, 12:58 AM Thread Starter
Here the main frame is taking shape motor plates are on and plates to hold them welded in also screw tensioner to push up on motor plate to adjust drive chain after a test run i put in a idler sprocket in front and below drive sprocket to get enough chain tension Main tools are welders plasma cutter drill press old 9 inch swing southbend lathe grinders cutoff saw etc Yes i have lots of treasures Some people call it junk
ID:	1889890   Click image for larger version
ID:	1889898   Click image for larger version
ID:	1889906   Click image for larger version
gordonr is offline
post #7 of 56 Old 02-01-2017, 10:17 AM
I see you have a couple of nice Char-Lynn 2000 series. What are they 4 cu-in? Did you use a variable volume pump(s)?
Hydronerd is offline
post #8 of 56 Old 02-01-2017, 10:28 PM
I thought I typed 24!
post #9 of 56 Old 02-01-2017, 11:53 PM
PM's only
Whirly's Avatar
now this is a cool project..
4-JD 60's 2-JD 70's JD R-72 5-JD 100 2-JD 110 JD 111 2-JD 112 JD Scotts 2048 JD Sabre 1742
WH RJ-58 WH Lawn Ranger WH 654 WH 854 WH B-81 2- MF 14 Artic Cat Lawn Lion
Craftsman DLT 2-Craftsman GT 6000 TrustWorthy 24 CC 70 CC 100 CC 129
Whirly is offline
post #10 of 56 Old 02-02-2017, 01:46 AM Thread Starter
Some more photos engine is 15 hp from princess auto motors are 18.7 cu. in pump i finally used is 12 gallons gear pump. tank i built is about 7 gallons spool valve is 5 section also i put in a brand flow control bypassing back to tank for very fine control
ID:	1891266   Click image for larger version
ID:	1891274   Click image for larger version
ID:	1891282   Click image for larger version
gordonr is offline
post #11 of 56 Old 02-02-2017, 03:41 AM
Mark in Portugal's Avatar
very neat, very cool.
Your pictures makes me feel like getting out to the shop and doing some creating.
In other words, inspiring work.
Mark in Portugal is offline
post #12 of 56 Old 02-02-2017, 07:53 AM
That's a Vickers vane pump in the pictures. So you changed it. Do you know displacement or what rpm you get 12 gpm?
post #13 of 56 Old 02-02-2017, 03:10 PM Thread Starter
Gear pump i am using .732 cu inch so about 12 gallons at full rpm but i normally run 2800 to 3000 rpm so 9 or 10 gal per min Here is mounts for cyl still just bolts here later i built pins In the picture you can see my ramrod its about a 1984 its in need of new hyd motors but still works the wife claimed it I built it about 8 inches longer and 8 inches wider than ramrod you can see wings on the back i really like can rest against or stop from getting thrown off I made wheel spacers 4 inches deep 5 hole 4.5 inch to 4 bolt golf cart or trailer wheels tires are 20 10 8 rear 18 10 8 front for snow and ice i put on narrower tires and chains i still have finishing touches and paint when weather gets warmer The bucket is 42 inch plus a 36 inch bucket and pallet forks and a blade that needs finishing
Name:	2016-02-21 11.28.53.jpg
ID:	1891506   Click image for larger version
ID:	1891514   Click image for larger version
Name:	2016-06-23 20.20.48.jpg
ID:	1891522   Click image for larger version
gordonr is offline
post #14 of 56 Old 02-18-2017, 08:12 AM
TomasR's Avatar
what a great build, and inspiration. Now I want to build one!!. well done sir.
TomasR is offline
post #15 of 56 Old 02-18-2017, 09:55 PM Thread Starter
I hope to have a few more pictures in the near future i am working on a hood and cover and finish off other parts and paint and decals
gordonr is offline
