Home made leaf vacuum....need ideas - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 12-21-2009, 03:34 PM Thread Starter
poncho62's Avatar
Images: 7
I want to build a leaf vacuum for next year. Want to mount it on a trailer to tow behind a lawn tractor. I have the trailer, a 6 hp engine, but am wondering what to do for a blower. I did a search of the forums and saw that some are using old chipper/shredders. I have an old Mighty Mac, but it is pretty big.....and I don't see how one of these is going to get the suction.
I am wondering if there is a type of industrial blower that I could use? I will have a hose from my mower deck to this blower and then up to a bin in the trailer..........Any ideas out there. Looking to build something like this......
Ford LGT100
Ford LGT125
Ford LGT145(sold)
Ford LGT165
John Deere STX38
Ontario Rodders
poncho62 is offline
post #2 of 7 Old 12-21-2009, 04:39 PM
Re: Home made leaf vacuum....need ideas
I have built several leaf vacs and suggest you look for a trak vac unit and use that as a pattern to build yourself the housing then you can purchase an impeller as a replacement part from trak vac. The impellers, while simple to make, are tough to balance properly without proper equipment so I would just buy one.
Most of the commercial units mount the impeller on the engine crankshaft though I dislike this approach because it will eventually damage the crank when the impeller gets out of balance from sucking up sticks and stones. I use a separate shaft and pillow blocks to mount the impeller and drive it with a v belt to the engine. This provides some protection to the engine if you jam the impeller and allows you to increase the rpm on the impeller which will increase the suction.
Bart is offline
post #3 of 7 Old 12-21-2009, 06:23 PM Thread Starter
poncho62's Avatar
Images: 7
Was thinking along that line too.........but, where can I get the impeller unit? Any ideas what will work?
Ford LGT100
Ford LGT125
Ford LGT145(sold)
Ford LGT165
John Deere STX38
Ontario Rodders
poncho62 is offline
post #4 of 7 Old 12-21-2009, 11:40 PM
Boyd's Avatar
Images: 10
Look for a large 2 stage snowblower and use the 2nd stage. I have one from Canado made in the 70s I think, that was 2 stage but had a 90 degree gearbox that ran to the first stage. It doesn't have a shaft going foreward from the 2nd stage.
My Horses: Toro 520xi & 522xi, 40" Berco, Toro 44" 2 stage blower, 48" push blade, 50" belly blade, 52" deck. Toro 5xi prototype hood. Parting out 2 Toro 266-H,1 268-H, JD Sabre 20/46 mower deck. For sale Toro 44" snowblower for 117, 118 & 120 Groundsmaster and Proline. WTB: for Toro Xi series 52" deck 78370/78375 and a mule drive for a 79365 single stage snowblower.
Boyd is offline
post #5 of 7 Old 12-21-2009, 11:47 PM
Here's the link to the manufacturer's site http://www.trac-vac.com/
You can read through and see which models might be most appropriate for what you want to do. Download their manuals for part details. You can get the parts through any dealer--I got mine through a JD dealer.
This is a pretty popular brand so you shouldn't have much trouble finding ones to look at or maybe even pickup a used unit with a trashed engine. You might also inquire of dealers to see if any have used parts/damaged units they would sell cheap.
Bart is offline
post #6 of 7 Old 12-22-2009, 12:12 AM
walter g's Avatar
If you can form and roll sheet metal you can build some of the parts you need. If not you'd do better looking for a trac-vac with a bad motor.
I thought about building one myself but it would cost to much. If you do build one there is a guy on Ebay selling the two hoses for 120 bucks brand new.
There is a company that sells the deck adapter boot for any tracvac style unit.
Adapter is here. http://www.trac-vac.com/
Hoses are here. http://cgi.ebay.com/DIXIE-CHOPPER-EX...item35a5996201
I believe the adapter boot is around 200. But you'd have to check.
It adds up real quick. If you can think of a cheap way to do it let me know.
Walter
walter g is offline
post #7 of 7 Old 12-22-2009, 12:40 AM
Here is a good source for hoses http://www.wynnenv.com/flexible_hose_Lawn.htm
If you want something that will last for a long time get the urethane hose--pvc will self destruct quickly.
Bart is offline
