Screw driver left inside front tire - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Motorcycles Our 2 wheeled machines
post #1 of 24 Old 04-06-2012, 11:46 PM Thread Starter
jayvee43's Avatar
Question:
Just a quick question to motorcycle mechanics out there. Is it possible for some reason to leave a 6 to 8 inch long screwdriver inside a tubeless tire on a motorcycle tire change, keep in mind that the screwdriver would be loose inside the tire, and the tire in question would have been balanced and road tested.
I say it is impossible to even atain a proper wheel ballancing, let alone not feel it during the road test after assembly, What say you??
jayvee43 is offline
post #2 of 24 Old 04-07-2012, 05:32 AM
Still lovin' the 322!
PA318Guy's Avatar
Re: Screw driver left inside front tire
If they did a simple bubble balance they could have "balanced" the tire, but I bet the number of weights needed to do so would be sizeable. You would never have heard the screwdriver in the tire doing a road test but it should have made it shake pretty bad moving around throwing the balance off!
Current Machine JD 322
PA318Guy is offline
post #3 of 24 Old 04-07-2012, 07:40 AM Thread Starter
jayvee43's Avatar
I agree with you, I am asking because a friend mechanic is being accused of leaving a screwdriver in a motorcycle tire, and at That shop They use an electronic balancing machine, and road test each and every repairs to tires, it's the law,.
Even if a mistake was made, with the screwdriver, the tire machine would have not returned to 0.0 grams and the installer would have probably not felt it, BUT the road tester would have been troubled with the blurred vision from vibration, NO?
This one is a mistery, and I'm having trouble believing the Other Shop's Mechanic who claims he found this screw driver inside this tire.
Something like that makes me
jayvee43 is offline
post #4 of 24 Old 04-07-2012, 07:58 AM
Collector of many tractors
Kbeitz's Avatar
Maybe one from a sewing machine...
Kbeitz is offline
post #5 of 24 Old 04-07-2012, 08:14 AM
Just Have a Little Faith!
Did the other shop produce the accused mechanic's screw driver???
LilysDad is offline
post #6 of 24 Old 04-07-2012, 08:26 AM Thread Starter
jayvee43's Avatar
Yes in fact they did, it was one of those "chain store brand"
Hummm!
jayvee43 is offline
post #7 of 24 Old 04-07-2012, 08:31 AM
Dude11's Avatar
If they can leave sponges and metal instruments in a guys gut--who knows???? Anything is possible.
Dude11
Dude11 is offline
post #8 of 24 Old 04-07-2012, 02:44 PM
forkz
forkz's Avatar
Images: 33
why was it took back off just wandering
country in her soul but she loves to rock n roll charlie daniels
forkz is offline
post #9 of 24 Old 04-08-2012, 06:43 AM Thread Starter
jayvee43's Avatar
The other mechanic said it went flat. come to think of it, if it is tubeless, and went flat, he would have needed a replacement tire would he not?
I mean you can't patch a tubeless motorcycle tire right?
jayvee43 is offline
post #10 of 24 Old 04-08-2012, 07:07 AM
ggsteve's Avatar
Yes, I believe a screw driver could have been left in the tire.
ggsteve
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H1 80 Cart
72 JD 110 parts
78 JD 316K 49 blower
84 JD 214 39 deck 43 blade
Woods box blade
74 Concord (MTD) 990
ggsteve is offline
post #11 of 24 Old 04-08-2012, 08:17 AM
What is the purpose of putting a screwdriver in there? I have used a screwdriver to mount a tire, but I don't put it inside.
LilysDad is offline
post #12 of 24 Old 04-08-2012, 08:27 AM Thread Starter
jayvee43's Avatar
I donno ask Ggsteve, he seem to have a purpose for leaving screw drivers in there
jayvee43 is offline
post #13 of 24 Old 04-08-2012, 09:19 AM
Jeff in PA's Avatar
I would want to see the screwdriver and the tire to see what marks were made. If a screwdriver was left in the tire, the screwdriver itself would be worn, the inside of the tire would be gouged and the rim would have plenty of marks.
If they fail to supply all three for inspection, I would say "tough bullcrap, you're full of it"
Jeff in PA is offline
post #14 of 24 Old 04-08-2012, 09:55 AM
The Travelin' Mod
davidg's Avatar
i agree with this!
as to leaving one in the tire, a guy i work with will sit a tool down where ever he happens to be when he decides he no longer needs it in his hand. maybe the tire shop guy has the same issue. my installer has been known to set tools down on the floor, boxes, carts, dumpster, building cross member, and once i found his drill in the sink in the men's bathroom. and he wonders why his tool box is always missing several items! this is exactly why my tools are always locked up in my truck!
Check out our new HOMEPAGE
davidg is offline
post #15 of 24 Old 04-09-2012, 07:37 AM Thread Starter
jayvee43's Avatar
Thanks guys, I'll be sure to let the mechanic know your support.
The machine he was using is this one. very accurate machine. It is effective to the 1/4 Oz. and extremelly difficult to screw up. (aparently)
http://www.youtube.com/watch?v=roff9eV3HwU
jayvee43 is offline
