6 lug Toyota fit 6 lug Chevy? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Trucks 2 Wheel Drive , 4 Wheel Drive, Big or Small
post #1 of 23 Old 12-30-2009, 10:57 PM Thread Starter
Father of 8!LordHelp'sMe!
Anyone know if the six lug wheels off of an older Toyota will fit a six lug full size Chevy Blazer?
littletoes is offline
post #2 of 23 Old 12-31-2009, 02:34 AM
Boyd's Avatar
Images: 10
Re: 6 lug Toyota fit 6 lug Chevy?
I think the bolt spacing is the same but the stud size may be different. Are the center holes of the wheels the same? What kind of lug nuts will you use? Part of what makes a wheel "safely" bolted to the axle or hub is it being centered whether it be with lug nuts that have an acorn shape. Other wheels are centered via the hub on the end of the axle or front hub.
My Horses: Toro 520xi & 522xi. Toro 5xi prototype hood. For sale Toro 44" snowblower for 117, 118 & 120 Groundsmaster and Proline. WTB: for Toro Xi series 52" deck 78370/78375 and a mule drive for a 79365 single stage snowblower.
Boyd is offline
post #3 of 23 Old 12-31-2009, 03:08 AM
Master Dismantler
AcreFarm's Avatar
Images: 7
I swapped wheels between a '91 Toyota and an '85 Chevy without any issues, both sets used acorn lug nuts. The Chevy had American Racing wheels, not the originals. Toyota wheels can be run on a GM, but stock steel GM wheels won't work with a Toyota, the center hole is smaller.
AcreFarm is offline
post #4 of 23 Old 12-31-2009, 07:12 AM
Collector of many tractors
Kbeitz's Avatar
I though toyota and Ford was the same....
Kbeitz is offline
post #5 of 23 Old 12-31-2009, 07:27 AM
junk_jivin38's Avatar
yes,i have swapped them on several different trucks...as others have said,use the acorn style lug nuts to keep the wheel centered and tighten them evenly a little at a time....the torque sequence (as i learned it) is to torque every other nut,clockwise ,going around twice...
also,the bolt pattern is the same on the 15 and 16-inch wheels
Kbietz...i think its ford and dodge are interchangable
BTW...i have a set of 15" turbine style wheels i need to get rid of...1 is broken at the flange from an overly-agressive tire-changer...cheap!
junk_jivin38 is offline
post #6 of 23 Old 12-31-2009, 08:55 AM
5000 posts and climbing
m.jodrey's Avatar
Yes they are the same.
Maynard
1963 Bolens 800,1972 Bolens 1256, 1972 Bolens 1886, 1973 Bolens H16, 1978 Massey 1655, 1961 Cub Cadet Original, 1979 Cadet 85, 1980 Cub Cadet 482, 1963 Gravely L, 1993 Ford 6640 4X4,2008 Kubota 2110 diesel,1970 Bolens 1053,2002 John Deere JE63S self propelled lawn mower
m.jodrey is offline
post #7 of 23 Old 12-31-2009, 09:39 AM
bb609's Avatar
Same bolt patterns but different sized centering hubs, Chevy being the smaller of the two.
bb609 is offline
post #8 of 23 Old 12-31-2009, 11:29 AM
Junk Collector
tractorkid94's Avatar
Yes, the pattern is the same. I have had 6 lug wagon wheels off of a Toyota pickup fit a fullsize Chevy Blazer.
199? Craftsman II 18hp 44"
2001 Poulan Pro 18.5hp 42"
Bolens 800 project
tractorkid94 is offline
post #9 of 23 Old 12-31-2009, 11:57 AM Thread Starter
Thanks guys, ya'll always have quick answers for me!
I may have to just buy some lug nuts now.
My old blazer has the older style aluminum rims that take the lug nuts that have the long thin shanks that go inside of the rim. I don't think they even make them anymore.
I have the opportunity to get some studded snow tires at a great price on Toyota rims.
Anyone know the thread pitch of the studs on a Blazer now??? Full of questions, ain't I?
Thanks again guys, you're a big help.
post #10 of 23 Old 12-31-2009, 12:07 PM
bb609's Avatar
You may find that you need centering rings for them given the lugs are not centering lugs but I'm guessing.
bb609 is offline
post #11 of 23 Old 12-31-2009, 11:01 PM
certified tractor nut
amf1414's Avatar
what year blazer if it is a later model they will be a metric thread if older it may be a 1/2-20 thread
01 craftsman lt1000 15.5 b&s
amf 1414 gt k341 kohler
49' ferguson to-20
49 farmall H restoring it now and i'm not going to have it done for awhile i want it to be perfect
R.I.P socks 07/08/96 - 07/22/2010
http://www.powerequipmentforum.com/ come check us out
amf1414 is offline
post #12 of 23 Old 12-31-2009, 11:43 PM Thread Starter
'87 , Thanks!
post #13 of 23 Old 01-01-2010, 02:07 AM
amf1414's Avatar
i'm pretty sure that an 87 would be metric so it is going to be either a 12 x1.5 or a 14 x 1.5
49' ferguson to-20
amf1414 is offline
post #14 of 23 Old 01-01-2010, 03:07 AM
Older 6 Lug GM's had 7/16 x 20 thread lugs..newer metric ones have 12mm x 1.5 pitch ones...Toyota's 6 lugs had the same bolt pattern but the centers dont always fit ,on OEM steel rims anyway..
Tractor-Holic is offline
post #15 of 23 Old 01-01-2010, 11:56 AM
if it is a full size Blazer (not an S 10 version) they had standard thread all the way til that body style stopped in 91;
chevy pickups changed body styles in 88 for 1/2 and 3/4 ton weights; 89 and some '90 1 tonners were still 73-87 body; Blazers and Suburbans didn't change body styles til '92! depending on what rim design you want look at Dakotas newer than 91, /Durango's and (I think) even Vipers as well! these were also 6 lug; and I know for sure taht at least til 96 a Dakota had a 1/2-20 stud; NOT metric.
Don B. is offline
