Tell Me Why ? (rubbing Alcohol) - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Car Talk Auto shop and car discussions
post #1 of 23 Old 07-05-2008, 12:50 PM Thread Starter
Old as Sin
silver hair deere's Avatar
Yikes Tell Me Why ? (rubbing Alcohol)
was at fred's today , saw a man pour two bottles of rubbing alcohol in his gas tank . wanted to ask him but he looked to mean , and it was too hot to get my butt kicked in the sun , sooooooooo why did he do it ??
silver hair deere
silver hair deere is offline
post #2 of 23 Old 07-05-2008, 01:16 PM
10,000 +posts!
Re: Tell Me Why ? (rubbing Alcohol)
He heard something under the hood rubbing? No doubt he couldn't find any Drygas, acetone, Bardahl, Wizzer Myserie Oil, SPT, Mower Honey, possum pee or bat vomit. People will put anything in a gas tank that they think "works"... Sometime all it takes is "...I heard..."
HydroHarold is offline
post #3 of 23 Old 07-05-2008, 01:17 PM
johnsonmk's Avatar
silver hair deere
My guess is he thinks it will help. I'm not so sure.
Mike
johnsonmk is offline
post #4 of 23 Old 07-05-2008, 01:17 PM
BAMA10's Avatar
He may have got some water in his tank. Alcohol will help rid the tank of water without really damaging the vehicle. Thats what i have been told. May or may not be true.
BAMA10 is offline
post #5 of 23 Old 07-05-2008, 01:37 PM
The Travelin' Mod
davidg's Avatar
back in highschool a friend had an alcohol racing motor in his truck. every fill up he had to add a couple bottles to the tank.
as far as it getting rid of water in the gas, both alcohol and gasoline are lighter than water. neither would do much other than force all the water to teh bottom.
davidg is offline
post #6 of 23 Old 07-05-2008, 02:06 PM
10,000 +posts!
Well, if you must know...
http://en.wikipedia.org/wiki/Isopropyl_alcohol#Uses
"Isopropanol is a major ingredient in "dry-gas" fuel additive. In significant quantities, water is a problem in fuel tanks as it separates from the gasoline and can freeze in the supply lines at cold temperatures. The isopropanol does not remove the water from the gasoline. Rather, the isopropanol solubilizes the water in the gasoline. Once soluble, the water does not pose the same risk as insoluble water as it will no longer accumulate in the supply lines and freeze..."
post #7 of 23 Old 07-05-2008, 06:54 PM
irwin's Avatar
The use of ethanol (up to 10% by volume) mixed with gasoline at the pumps does the same thing, not sure if adding any other dry-gas product would do anything more than what's in gas now. Has anyone heard of gas lines freezing in the last few years? My understanding is, with ethanol in our gas, dry-gas is a waste of money.
.......Tim
Kubota L35 TLB, IH 2424 w/FEL, NH L555 skid steer
65" OBG grapple, PHD, 72" landscape rake, 72" box blade
91' Cub Cadet 1541, 69' Deere 110, 2 Craftsman LT's
irwin is offline
post #8 of 23 Old 07-05-2008, 06:58 PM
Dan
Milwaukee's Avatar
I have see one guy that look so mean because face it scare me when he walk to me. He was ask me where I get those nice tires on my truck. Well found that he was very nice guy but don't judge on his face.
Well did you see him fill gas tank with E85 flex? that could be he try improve mpg by have more gas less water.
I have no idea.
Case 222
Ford 601
Please join this
Milwaukee is offline
post #9 of 23 Old 07-05-2008, 09:11 PM
Fla Dave's Avatar
Images: 6
adding alcohol depends on what kind of fuel system the vehicle has. Water in a fuel injection system rarely presents a problem. However, if it was older car with a carburator and depending on the design of the float bowl adding alcohol will help pass the water through the system. I have an old Jeep with a rochester 2 bbl carb., the jets are at the bottom of the carb. Any amount of water in the gas , because the water settles to the bottom of the bowl, makes it stumble and stutter like Mel Tillis. A bottle of rubbing alcohol fixes the problem every time.
Just a word of advice, If women don't find you handsome then try to be handy.
Fla Dave is offline
post #10 of 23 Old 07-05-2008, 10:48 PM
1086's Avatar
Images: 11
"I Heard" - we're getting alcohol in the gas now so the gasoline companies can sell us a little water mixed in @ $4.00 a gallon.
1086 is offline
post #11 of 23 Old 07-05-2008, 11:11 PM
Cool Re: Tell Me Why ? (rubbing Alcohol)
If you ever want to impress someone or suggest a science project for one of your little ones, have them fill two glasses, one almost full to the top with water and the other one almost full with pure (Most rubbing alcohol is a 70% or 92% variety.) alcohol. Then have them pour one glass into the other glass and the contents will NOT spill over.
Bountyhunter
Bountyhunter is offline
post #12 of 23 Old 07-06-2008, 12:20 AM
Greenster's Avatar
I would think if you were doing this, you would find some 100% isopropyl. Rubbing alcohol (as mentioned above) is typically 70% alcohol and 30% WATER. Sounds like he had the right idea but the wrong product.
GREENSTER
JD 2305 - 48" Eagle Box Blade - JD 647 48" Tiller - 62C MMM w/Mulching Kit & Independent Lift - 200CX FEL w/49" bucket
Greenster is offline
post #13 of 23 Old 07-06-2008, 09:05 PM
Has anyone seen ChimChim?
Brett-JDX748's Avatar
Ethanol (or any alcohol base) is NOT soluble with petroleum distalates. They (the refineries) have to centrifuge the ethanol into the fuel so that it is evenly disbursed. If a vehicle (like a boat) sits too long then the ethanol phase seperates and starts to absorb massive quantaties of water (what alcohol does best).
It's garbage and I feel the President of the united states should be sued for forcing the garbage on us. Ethanol has and will continue to do more harm than it does good.. It's no better than MTBE was.
X748 Ultimate,
Diesel, 4x4, 62C MMM, SE Seat, Quick Hitch,
54" Plow, 26Gal Sprayer, Soft Cab, 10P Cart.
That knockin, ain't a loose rod, Son!
Photos
Former Fleet:
2009 Craftsman GTS5000 Excellerator - Sold
Photos
2006 John Deere 3320, FEL, Backhoe, 62 MMM - Sold
Photos
2005 Cub Cadet 6284D FEL, Backhoe , 70" rear finish mower - Bought back, LEMON
Photos
Brett-JDX748 is offline
post #14 of 23 Old 07-06-2008, 09:47 PM
10,000 +posts!
Is it possible this guy was just topping off his load of 'shine to be delivered with his electric car....?
post #15 of 23 Old 07-07-2008, 07:56 AM
Anything With Wheels
Argee's Avatar
I think Harold nailed it!
Randy G
Argee is offline
