What is this part called? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Car Talk Auto shop and car discussions
post #1 of 7 Old 03-18-2012, 01:34 PM Thread Starter
ggsteve's Avatar
I took the hard top off of the BMW Z3 this morning. When we went to raise the power top it raised for a couple seconds, I heard a "pop", and the top dropped back into the boot. After a little investigation I found that the linear actuator was no longer connected to the frame of the top, and the connector between the two is no where to be found. I don't know if this part is something I could find at an auto parts store or if I need to go to (gasp!) BMW. Here is the connector end of the linear actuator. It looks like the same fastener used on a lot of trunk lid shocks:
Here are two views of the attachment point on the convertible top frame. It looks like the hole is threaded.
The fitting, whatever it is called, must have unscrewed itself over the years and finally popped out today. I think the very outer threads stripped, but the majority of the threads in the hole look good. Does anyone know if this is a standard connector, or am I calling (gasp!) BMW?
EDIT: By the way, this is Murphy's Law in full force. I made the very last payment on this car Friday!
ggsteve
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H1 80 Cart
72 JD 110 parts
78 JD 316K 49 blower
84 JD 214 39 deck 43 blade
Woods box blade
74 Concord (MTD) 990
ggsteve is offline
post #2 of 7 Old 03-18-2012, 01:38 PM
The Magnificent
D-Dogg's Avatar
Re: What is this part called?
Ball and socket joint?
You could take measurements and try McMaster-Carr, or just bite the bullet at BMW. I didn't think my BMWs were that expensive when it came to parts, but then again, I had to ask for them in German, so maybe it was cheaper over there.
D-Dogg is offline
post #3 of 7 Old 03-19-2012, 08:57 AM
Canawler's Avatar
Banks open in a few minutes. Time for your second mortgage.
---Jim
It's only money, you make more every day.
'74 Agway/MTD 990
'93 Troy-bilt GTX18
'74 Allis Chalmers Homesteader 8 (X2)
?? Simplicity Broadmoor 717
?? Pennsylvania Meteor 1010
Canawler is offline
post #4 of 7 Old 03-19-2012, 04:43 PM
Has anyone seen ChimChim?
Brett-JDX748's Avatar
Steve,
Here ya go!
http://www.mcmaster.com/#ball-studs/=gqggjh
Match up the dimensions you need and go to town!
X748 Ultimate,
Diesel, 4x4, 62C MMM, SE Seat, Quick Hitch,
54" Plow, 26Gal Sprayer, Soft Cab, 10P Cart.
That knockin, ain't a loose rod, Son!
Photos
Former Fleet:
2009 Craftsman GTS5000 Excellerator - Sold
Photos
2006 John Deere 3320, FEL, Backhoe, 62 MMM - Sold
Photos
2005 Cub Cadet 6284D FEL, Backhoe , 70" rear finish mower - Bought back, LEMON
Photos
Brett-JDX748 is offline
post #5 of 7 Old 03-25-2012, 08:30 AM
Tomadvanced's Avatar
Go to realoem.com type in the last seven digits of your vin and you can look up the part #.
2011 X729, Heated Soft Side Cab, 47" Snow Blower, 54C Mower Deck, MC519 with Power Flow, 45 Loader, 26 Gallon Sprayer, JD 48" Aerator, Spyker 12v Spreader
Tomadvanced is offline
post #6 of 7 Old 03-25-2012, 09:12 AM
10,000 +posts!
glenn27's Avatar
Originally Posted by Brett-JDX748 View Post
Steve,
Here ya go!
Same exact type of ball/stud arrangement as on my Jeep lift gate, when I just replaced the actuators....New ones came with mine--so I belive it's a standard auto thing...belive it was a 15mm socket to install....
glenn
Jimmy Buffett
glenn27 is offline
post #7 of 7 Old 04-20-2012, 10:12 PM
Must be a common issue as the last one I put a top on had one loose,was able to retap and install.
junkyardjeff is offline
