Berco remote chute deflector seized - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 01-21-2011, 09:04 AM Thread Starter
ggsteve's Avatar
I have a 2005 Berco Northeast 44" snow thrower (# 700374) that works great except for one thing. I purchased the remote chute deflector (# 700239) two winters ago, and from time to time since new the chute control has frozen up inside the telescoping mechanism inside the spring attached to the chute itself. The cable is fine. In the past I have been able to thaw it out either by using a hair drier or even just breathing on it for a few moments. Not anymore. For the last week it has been seized in place, even at temps well above freezing.
Anyone ever seen this or have any suggestions? I can't get at the telescoping rod without taking it all apart because the rod is inside the tension spring.
ggsteve
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H1 80 Cart
72 JD 110 parts
78 JD 316K 49 blower
84 JD 214 39 deck 43 blade
74 Concord (MTD) 990
ggsteve is online now
post #2 of 3 Old 01-21-2011, 11:16 AM
GrassMeUp's Avatar
Re: Berco remote chute deflector seized
Other than taking it off and soaking it in anti-freeze or maybe lubricating it with low vis synthetic oil
however
this is now available
Haven't done one myself, kinda hard to justify since I live right on that snow/rain line for the past 4 storms
http://www.sears.com/shc/s/p_10153_1...6&blockType=G6
2010 Cub Cadet LTX1046
48" Bercomac Northeast snowblower
Past> 1994 indestructable Craftsman GT6000
Kubota BX2200D Loader
GrassMeUp is offline
post #3 of 3 Old 01-22-2011, 05:10 PM Thread Starter
ggsteve's Avatar
I figured it out. The outer sheath had bent a little bit. I straightened it and the inner sleeve can slide in and out now. It was binding before.
ggsteve
71 JD 140H1 80 Cart
72 JD 110 parts
