Need bushings JD part M46482 which is NLA. Need this parts’ dimensions so I can find other source, anyone out there have this info & or source?
My measuring of the shaft says the ID would be 5/8”, can’t get good measurement for the OD. I’m trying to avoid tearing it down until I have the parts in hand, wanting to keep it mobile to keep it out of my way. If I have to will pull it apart.
Is my neighbors machine, we have a deal, he does my tile and fine wood work, I do his wrenching.
Did someone else’s 1032 couple years back and all bushings available then, too bad lots of this series/vintage machines in use and simple bushings not available including no drawing to view.
Thanks
JD part M46482, sub for part M45177, Number 13 in drawing
Thanks
