sod cutter help - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 08-21-2008, 03:31 PM Thread Starter
sod cutter help
hi i'm new to this site so i may be asking a question that has already been posted [but i couldn't find it] i'm looking for a plan to make a 3 point sod cutter? or a place to buy 1 [cheap of course] thanks, kycoot
kycoot is offline
post #2 of 11 Old 08-21-2008, 04:33 PM
Retired MTF Admin
Ken N Tx's Avatar
Images: 60
Re: sod cutter help
kycoot..
Thats a good question...I might be interested in one myself to pull behind the 2N..
Enjoy all of the many Forums on MTF..
Ken N Tx is offline
post #3 of 11 Old 08-21-2008, 05:07 PM
MEMBER
TOMMY's Avatar
Re: sod cutter help
Kycoot,enjoy the forum!!
~TOMMY~
2010 JD X320
48 FARMALL SUPER A
74 Sears ST-12(Disassembled)
74 Sears ST-12
73 Sears ST-12
TOMMY is offline
post #4 of 11 Old 12-18-2008, 01:24 PM
mdmre's Avatar
Images: 3
Re: sod cutter help
I made one a couple of years ago. I mounted it to the 3 ph on a 20 hp garden tractor. I designed it so the cutting bar would be about 3 to 4 inches below ground. This would slice the grass just below the roots and it worked very well. I made it as wide as the 3ph arms would spread. I also put the top link attach point higher than usual, this made the attachment swing in an arc when raised or lowered. This helps to get the thing started in the ground.
I have a picture or two if you are interested.
mdmre is offline
post #5 of 11 Old 12-18-2008, 02:49 PM
Re: sod cutter help
please post tthose pics if you can. what did you use for the cutting bar.
david doyle is offline
post #6 of 11 Old 12-18-2008, 02:51 PM
Retired MTF Admin
Ken N Tx's Avatar
Images: 60
Re: sod cutter help
mdmre....
Yes by all means lets see the picture..
Ken N Tx is offline
post #7 of 11 Old 12-18-2008, 05:48 PM
Dude11's Avatar
Re: sod cutter help
The only sod cutter i've seen and used had the blades virberating from side to side so as to cut the sod & dirt,plus a gauge so you didn't dig too deep.Looks like if you just pull a blade you would ball-up the sod.Unless you could build it with the blade at a small angle.What ever you figure out
Dude11
Dude11 is offline
post #8 of 11 Old 12-19-2008, 05:51 PM
mdmre's Avatar
Images: 3
Re: sod cutter help
I cound only find one picture of the sod cutter. It will have to wait until spring to get a picture of the sod cutter in action. I used 2" x 2" angle for most of the frame and 1.5" flat bar for the rest. I used a grinder to sharpen the leading edge of the flat bar. The flat bar is the actual cutting edge for the grass and soil. To determine how big to make it, I put my 3ph in the lowest point, measured to the floor and added 3 to 4 inches and this is the length from the bottom to the pin. I figured that about 6 inches of heighth for the flat bar, the part that might be in the dirt would be sufficient. I shortened my top link to it's shortest setting. I then put the back of the tractor on a 4" block of wood, and measured from the floor to where the top link would possibly attach and give me a perfectly vertical alignment. This is where I mounted the attach point for the top link. This arrangement leads to the cutter swinging out and up in an arc when raised and exactly the opposite when lowered, almost the same type of action you get when you would dig with a shovel. This seems to get the cutter started in the ground easily. All the times I have used this, it cuts a nice path through the grass. There is no bunching of the grass. After a pass, I just roll up a section of grass and throw it in a wagon and haul it away. I have found one thing that I intend to change. That is to reinforce the 2x2 angle. Sometimes when cutting, the angle iron wants to flex a little where the two side pins are. This flexing is barely noticable. It has not bent or twisted the metal at all, I just noticed it once and figured I should fix it before it becomes a real problem. I plan to take a length of 1x1 angle and weld to the front side of the 2x2 angle to stop the flexing. I think it works pretty well and I have no complaints about how good it works. It has certainly saved me from lots of blisters and sore backs.
Name:	Sod Cutter.jpg
mdmre is offline
post #9 of 11 Old 12-19-2008, 05:59 PM
mdmre's Avatar
Images: 3
Re: sod cutter help
There is always another alternative that is tried and true and never fails. It even rolls the grass over for you.
mdmre is offline
post #10 of 11 Old 12-20-2008, 04:48 PM
Re: sod cutter help
Thanks alot for the pic and explaination. That will save me a lot of trial and error. really appreciate it.
post #11 of 11 Old 12-20-2008, 08:40 PM
mdmre's Avatar
Images: 3
Re: sod cutter help
Hope it helps everyone that is interested. One thing I would check before making things permanent. When I raise the 3ph all the way up, the top comes very close to my seat. I checked to make sure that everything would swing and move without hitting anything before I made the welds permanent.
For the cutting edge, I took an angle grinder and sharpened the forward edges of the flat bar to a 45 degree angle. So far, the edge has not dulled much that I can tell and it still seems to cut through the grass pretty good.
I suppose if you want more control over the depth you could add a depth wheel to each side. For my purposes, I thought that the 3 to 4 inch depth when fully lowered would do for me.
For those of you interested, I am just wondering if you are looking to cut the grass and save the grass for future use or are you looking to cut the grass off and throw it away. I have used this to remove the grass and prepare the area for a flower bed or garden and was never concerned with saving the grass. It is a lot easier to prepare a garden this way, trying to start a garden from scratch through the grass with a tiller can really shake you to death as well as the tractor and tiller plus it leaves a lot of grass that wants to regrow later.
Good luck everyone.
mdmre is offline
