54" Rear Blade Broke - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 26 Old 04-29-2011, 10:52 PM Thread Starter
Old as Sin
silver hair deere's Avatar
Setting on my sears gt grading the large ruts from last storm , happy as a clam , then i hear a pop , so what to do , ideas needed !!
Name:	Picture 006 (Large).jpg
ID:	155386   Click image for larger version
Name:	Picture 007 (Large).jpg
ID:	155387   Click image for larger version
Name:	Picture 011 (Large).jpg
ID:	155388   Click image for larger version
Name:	Picture 012 (Large).jpg
Silver Hair Deere
2014Craftsman YTS 4500
1989 Sears lawn tractor (5 bolt)
1996 MTD 696 needs front fixed
1998 Murry needs engine 12.5 B*S
1989 GMC 1500
1998 FORD RANGER
When one breaks down , i just drive or
mow with another
A PROUD MEMBER FOR 10 YEARS !!!!
silver hair deere is offline
post #2 of 26 Old 04-30-2011, 12:12 AM
HAMMAN
hamman's Avatar
Re: 54" Rear Blade Broke
From what it looks like to me, you need to gusset along each weld when you weld it back together. You might think about adding another arm weld on each side also. Didn't look like a good penetration on the original weld. Just my thoughts.
hamman is offline
post #3 of 26 Old 04-30-2011, 08:09 AM Thread Starter
Old as Sin
Thank you hamman ,your the only one to post a reply , will update with pictures .
Silver Hair Deere
1989 GMC 1500
1998 FORD RANGER
mow with another
post #4 of 26 Old 04-30-2011, 08:45 AM
HAMMAN
hamman's Avatar
Take your time and get a good penetrating weld when you repair. If I have gleaned anything from the guys and gals here is take your time and do it right. It should be better than new when you get done.
hamman is offline
post #5 of 26 Old 04-30-2011, 09:32 AM
I agree with hamman. It looks as if there was a minimum penetration of the original welds. Clean well,take your time and consider adding a gusset at the top and bottom of the arms.
Dave
DLF_IN is offline
post #6 of 26 Old 04-30-2011, 10:19 AM
fabforce1's Avatar
Thats the exact spot that mine broke, except yours broke nice and straight.
Mine got all bent up and i really have nothing to straighten it up. I have a vice and a big hammer...lol...i got it pretty straight but needs to be redone. I was in a hurry cus i needed to use it right away so i did the best i could to straighten it and re welded it and it did the job for the winter but with summer jobs coming it will need to be done better.
fabforce1 is offline
post #7 of 26 Old 04-30-2011, 10:41 PM Thread Starter
Old as Sin
I only have a HH 135 , did the best on welds , still have to add the gussets , how do the welds look ? i did bevel the piece i welded on , also if it's not good tell me how to improve it .
Name:	Picture 005 (Large).jpg
ID:	155551   Click image for larger version
Silver Hair Deere
1989 GMC 1500
1998 FORD RANGER
mow with another
post #8 of 26 Old 04-30-2011, 11:24 PM
Old Stonebreaker
The weld looks cold. If you have an O/A or propane torch, I'd preheat it real good before welding. Might want to grind that out and reweld w/ preheat. It's difficult to weld metal that thick w/ 135 amps. Just crank 'er up all the way, you don't have to worry about burnthru w/ this weld.
I'm sure you plan to, but weld both sides of the joint.
HTH,
Mike
mla2ofus is offline
post #9 of 26 Old 05-01-2011, 08:34 AM
life is good
farmtechdave's Avatar
I agree the weld does look a bit cold. Also it looks as there is only one pass. I'd of ground it down and done 3 passes with preheat, a good root pass then a couple finish welds to strengthen it up.
Dave
It's gotta be Morel season soon......
farmtechdave is offline
post #10 of 26 Old 05-01-2011, 09:27 AM Thread Starter
Old as Sin
Is it to late to pre heat and add extra weld or do i need to saw apart and start over ?
Silver Hair Deere
1989 GMC 1500
1998 FORD RANGER
mow with another
post #11 of 26 Old 05-01-2011, 11:14 AM
Old Stonebreaker
I'd get rid of the weld and start over w/ the preheat.
JMHO,
Mike
mla2ofus is offline
post #12 of 26 Old 05-01-2011, 05:19 PM
HAMMAN
hamman's Avatar
I agree on oreheat. My HH140 needs a little help once in a while when I get on thicher stuff. Once I get my new garage wired this spring I will be able to use my stick welder for thicker stuff. Look like you did a good job so far.Don't foget to back weld the joints. It woun't take long to get it done.
hamman is offline
post #13 of 26 Old 05-02-2011, 03:30 PM
Bevel it in and weld with 308-15 stainless, 1/8 " . You'll never get enough pen with a wire feed.
oldasrocks is offline
post #14 of 26 Old 05-02-2011, 06:14 PM
Expanding on my answer above.
Looking at the color of the metal both farther back and at the weld itself I'm going to assume it a poor grade of metal to start with. I've ran into this with some of my own equipt. The cheap rototiller I bought had to be cheap imported-read chinese- steel. Low grades shatter like cast iron does and does not weld well with standard techniques. thats why you were advised properly to preheat. But also use the stainless rod when aheres better. You could use FN-86 at $40 or so a pound but thats expensive and hard to find.
post #15 of 26 Old 05-03-2011, 08:57 AM Thread Starter
Old as Sin
All i have is a HH135 mig welder . And no extra money in may . What can i do .
Silver Hair Deere
1989 GMC 1500
1998 FORD RANGER
mow with another
