Shindaiwa Clutch Removal - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 12 Old 07-07-2009, 03:02 PM Thread Starter
LB10247's Avatar
New member here, I joined because of all the great Lawn Boy resources but I also have a chainsaw I need help with. I am trying to remove the clutch from my Shindaiwa 345. I assume there is a special tool needed, but does anyone have any do it yourself ways to get it off? I already have the piston locked, I just can't get a way to break the clutch loose. Attached is a pic of what it looks like. Thanks in advance for the help!
LB10247 is offline
post #2 of 12 Old 07-07-2009, 04:58 PM
Re: Shindaiwa Clutch Removal
It is most likely screwed onto the crankshaft with a left-hand thread- turn clockwise to remove.
rscurtis is offline
post #3 of 12 Old 07-07-2009, 05:36 PM
Junk collector
FergusonTO35's Avatar
There is a video on Youtube showing how to remove the clutch on a Husky that has the same type of clutch.
1955 Harry Ferguson TO35
1990 Murray 12HP/38"
1996 Murray 8HP/30"
Lots of weedeaters, chainsaws, blowers
FergusonTO35 is offline
post #4 of 12 Old 07-07-2009, 08:31 PM Thread Starter
LB10247's Avatar
It is definitely a left hand thread, but there is no real way to get a wrench on it.
Ferguson - do you happen to have a link to that video, I checked Youtube and couldnt find anything under "husky chainsaw clutch". Thanks a lot for your help!
LB10247 is offline
post #5 of 12 Old 07-07-2009, 09:03 PM
Rubber strap wrench.
engine2quarters is offline
post #6 of 12 Old 07-07-2009, 11:49 PM
Junk collector
Here ya go:
http://www.youtube.com/watch?v=cdqkIuVNUQc
Type in "chainsaw clutch" and several other videos come up also.
1996 Murray 8HP/30"
post #7 of 12 Old 07-08-2009, 12:19 AM
certified tractor nut
amf1414's Avatar
if you plan on replacing the clutch while its off you can remove it one of two ways. weld 2 bolts directly across from eachother and use a pry bar tu turn it. or method #2 drill 2 holes across from each other and insert 2 bolts in the holes and then use a pry bar to turn the clutch. hope this helps
amf1414 is offline
post #8 of 12 Old 07-08-2009, 02:18 AM
Junk collector
I don't know if this would work but maybe a blunt punch could be used to tap the edges of the clutch shoes in the correct direction. By the way, how old is that saw?
1996 Murray 8HP/30"
post #9 of 12 Old 07-08-2009, 08:45 AM Thread Starter
LB10247's Avatar
I thought of a rubber strap wrench but the clutch drum spins free so there is nothing to grab onto.
Ferguson - thanks for the link - Husky = Husqvarna, I shoulda guess that. I tried (very lightly) to knock on the clutch shoes, but I really didnt know if they are durable enough to be hitting on them. Are they usually solid enough to not risk breaking anything if I hit at them with a punch etc? I really dont know much about chainsaws in general, or this saw. Its a Shindaiwa 342, I got it from a friend who tried to get it going but to no avail. I always have a need for a small chain saw and as a freebie this one seems pretty nice. Its in really solid shape, but has been neglected. I took the entire saw apart to clean it out since it was full of greasy sawdust, and the entire fuel system had turned to rubber goo! I will attempt again to knock on the clutch shoes with a little more force this time. Thanks again for the help, I will report back later.
LB10247 is offline
post #10 of 12 Old 07-08-2009, 05:32 PM
Junk collector
I would try knocking the clutch shoes with a punch, I would bet thats how most Shindaiwa techs do it. That said, I can't guarantee the results as I've never removed this type of clutch before, all my saws use a nut. I would advise you to locate a new clutch and drum and be willing to buy it if necessary. The saw appears old enough to where replacement would be a good idea.
1996 Murray 8HP/30"
post #11 of 12 Old 07-08-2009, 09:37 PM Thread Starter
LB10247's Avatar
Ferguson - Thanks for all the help. I tried a punch, and it just didnt feel right, I could get a good enough hit on it. So I made up a small "jig" in my vise to lock the clutch shoes and I was able to twist the clutch right off. It looks to all be in good shape but I will definately double check everything out before it goes back together. Thanks again for all the help and advice!
LB10247 is offline
post #12 of 12 Old 07-09-2009, 12:24 AM
Junk collector
Good job, bro.
1996 Murray 8HP/30"
