Poulan Wild Thing, can you adjust the idle??? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 05-23-2009, 07:31 PM Thread Starter
Jeff T's Avatar
After all the schooling I've recieved I spent several hours cleaning, sharpening the chain, new spark plug and air filter, filed and reversed the bar and on and on.
It still is an absolute bear to start, won't idle... Any tips???
2004 John Deere LX280
Stihl FS 55, Stihl MS270
Off to greener pastures:
1994 John Deere STX38
Ryobi 767r, Poulan 2375 "Wild Thing"
Jeff T is offline
post #2 of 8 Old 05-23-2009, 07:40 PM
aceman
frank st amand's Avatar
Re: Poulan Wild Thing, can you adjust the idle???
yes carb has seals chain saw shop can adjusted the carb special tool to adjust the carb after the saw will be great to used it will not be the same saw and be easy to start and you will gain power too there a great saw when ajusted properly and not expencive to do it just finding one that can
factory setting is too lean there is two jets to adjust also saw will last longer
don't forget to used only weed eater oil it syntectic no snoke it the only oil to used
if you fail once that ok but twice get a beer
before you lose it
gt 235 repower vanguard 24hp 54 deck 46 plow
445 John deere the projet has started wish list loader snowblower,cab, heat, rear 3pt getting the hydro oil stop
2 yard carts
20 ton splitter
yes i french get confuse in spelling at times
frank st amand is offline
post #3 of 8 Old 05-25-2009, 05:59 AM
Ironmower's Avatar
Most likely it's your high/low RPM mixture screws, needs some tweakin' good luck!
Ironmower is offline
post #4 of 8 Old 05-25-2009, 08:50 AM Thread Starter
Jeff T's Avatar
I'll assume they are the two next to each other, what is the one screw above them for?
Jeff T is offline
post #5 of 8 Old 06-11-2009, 01:31 AM
Junk collector
FergusonTO35's Avatar
If it simply idles too low you can easily adjust the throttle stop to open the butterfly a bit more. I've owned a bunch of Poulans and they tend to idle way too low from the factory. Heres how I do it. Start the saw and cut a few logs to get it good and warmed up. Using the appropriate size screwdriver, turn the idle stop screw in until the engine speeds up enough to just start turning the chain. Then back it off some so that you have a smooth idle with no chain movement.
1955 Harry Ferguson TO35
1990 Murray 12HP/38"
1996 Murray 8HP/30"
Lots of weedeaters, chainsaws, blowers
FergusonTO35 is offline
post #6 of 8 Old 06-12-2009, 02:08 PM Thread Starter
Jeff T's Avatar
Looking at the saw there are 3 screws I could adjust. One on top marked "T" or the two side by side marked "L" and "H".
Which one are you referring to??
Thanks!!
Jeff T is offline
post #7 of 8 Old 06-12-2009, 08:46 PM
Lawnboy7229's Avatar
He is referring to the "T" screw, it adjusts the base rpm speed ot the saw. The low speed and high speed screws are to adjust the air/fuel mixture of the saws varying rpms.
So, to adjust your "T" screw, assuming you high speed is running ok and your low speed is ok, run the saw about half throttle, gently ease off the throttle, wait for it to come close to dying out then start adjusting your "T" screw to get the base speed. note set it low enough that it won't engage the clutch and move the chain.
Lawnboy7229 is offline
post #8 of 8 Old 06-12-2009, 10:21 PM Thread Starter
Jeff T's Avatar
Thanks Lawnboy! I'll be on it in the AM!
Jeff T is offline
