What to use for Bar & Chain Oil? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 47 Old 11-13-2011, 02:03 PM Thread Starter
Instead of paying ridiculous prices for oil, what can I use instead of Stihl or Poulan bar oil? Seems like snake oil just to lube your chain with some branded lube when prob most heavier oil in my garage will work. Thanks
hotajax is offline
post #2 of 47 Old 11-13-2011, 02:08 PM
I Love All Color Tractors
DJ in WV's Avatar
Images: 6
Re: What to use for Bar & Chain Oil?
I use the Tractor Supply brand. In my area, it's $8.79 per gallon and a gallon will last me one two seasons.
It's plenty sticky and I haven't had a problem with burnt or overheated chains. It works for me.
http://www.tractorsupply.com/tractor...1-gal--4469010
Challenge Met
Looking for a Technical Exchange Article? Here's an Index!
My YouTube Page
My Equipment:
1970 Gravely C10A
1971 Gravely 430
1972 Gravely 816
1973 Gravely Model C8
Eight other Gravely C's, L's, and LI's
1978 Massey Ferguson 1655
1982 Gravely 8123
1983 Troy Bilt Junior
DJ in WV is offline
post #3 of 47 Old 11-13-2011, 02:10 PM
I have a drain container set up in my garage for all my funnels and oil jugs. I use those drippings for my chainsaw bar oil. I also use partial containers of oil, trans fluid etc. that I come across.
sanfordanddaughters is offline
post #4 of 47 Old 11-13-2011, 02:21 PM
MrGiggles's Avatar
Images: 10
I've heard of people straining waste motor oil and running it through their saws. I haven't tried it but don't see why it would hurt anything. I've got a 7.3 PSD in the fleet that would drop half my winter supply of bar oil in one oil change.... I've also heard of using vegetable cooking oil if you're cutting something you don't want contaminated.
I could see used ATF working very well in the winter as it's thinner and more pourable. As long as it's not totally trashed with metal in it I would use it as well.
I've personally used straight 30wt motor oil, 80-90 gear lube, and hydraulic oil in my saws when I was in a pinch. Never had an oiling-system related failure.
That being said, I do prefer to use actual bar and chain oil when I can. One thing about that walmart Poulan oil though, it has a stink to it.
Mowers:
2005 Troy Bilt ZTR 42-19hp Briggs I/C 42" Deck
Chainsaws:
Husqvarna 50 Special, 20" and 16" bars
Stihl 066, 25" and 20" bars
Jonsered 2252 Autotune, 18" bar
Craftsman 2.1
Other:
Stihl FS90R with Brush Blade
1999 Kawasaki Bayou 220 ATV
Collection still growing.
MrGiggles is online now
post #5 of 47 Old 11-13-2011, 02:33 PM
Ken in NJ's Avatar
My chainsaws are part of my family, and I've always used store bought bar and chain oil. By the gallon it's not that costly. Like DJ I've used Tractor Suppy brand.
I would not give my kids outdated milk, I won't give my saws dirty or the wrong type of B&C oil either.
I'm funny like that.
Ken in NJ is offline
post #6 of 47 Old 11-13-2011, 02:38 PM
ggsteve's Avatar
My local guy carries Husqvarna bar oil. Why mess with cheaper stuff, it's not that expensive.
ggsteve
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H1 80 Cart
72 JD 110 parts
78 JD 316K 49 blower
84 JD 214 39 deck 43 blade
74 Concord (MTD) 990
ggsteve is offline
post #7 of 47 Old 11-13-2011, 07:44 PM
My Orange Jane Deere
orange j d's Avatar
Well my chain saw days are over, but when I did use them they got good ol drain oil and the lasted for years. And we did not have milk so the kids got the same. But if I were rich I would only use 3 in 1.
Sent from my FREE MTF APP PROVIDED BY MY FRIENDS AT MTF*****
Remember: Marriage is the number one cause of divorce.
orange j d is offline
post #8 of 47 Old 11-13-2011, 08:44 PM
Grand Sierra's Avatar
I just buy it @ Lowes mainly because I buy there Pro Mix oil there once you try it you" ll be hooked!
Grand Sierra is offline
post #9 of 47 Old 11-13-2011, 09:08 PM
Nitro-Fish's Avatar
The whole idea behind chainsaw bar oil is for it to be tacky so it will stick to the chain and drive teeth instead of just slinging off of the chain during use. I know people who use old oil, but I also know their saws are a lot more messy than mine to clean up at the end of the day, not to nemtion it gets all over their chaps, coveralls. shoes etc.
JD 3320 w/300CX loader
JD 790 w/419 FEL SOLD
Too many implements
Bobcat Zero Turn
Stilh FS 80 & 110
Shindiawa S 25
Stihl BR 600's
Chainsaws: too many
Nitro-Fish is offline
post #10 of 47 Old 11-14-2011, 12:29 AM
10,000 +posts!
If your chainsaw ain't worth real chainsaw bar oil, feel free to run old stale gas in it too. Motor oil is not worth anything for lubing a chain, it's not stringy, flies off, doesn't have the viscosity to really lube the tip (no matter what type tip your bar has) and it certainly can't perform at the drive sprocket. One case where cheap isn't better.
Something closer to chain oil is rear end or "hypoid oil" thinned with kerosene. Even that is better than new or used motor oil which has already been changed out because it's lubrication properties won't lube an engine. Just because it "looks like oil" doesn't mean it still is. But these words are from a guy that uses bars until the chain drive tangs start dragging the bottom of the groove after a bunch of bar resets and truings.
HydroHarold is offline
post #11 of 47 Old 11-14-2011, 05:57 AM
2 stroke enthusiast
echoman's Avatar
I agree. There is no replacement for true bar & chain oil. My cousin gave me a brand new saw several years ago he bought brand new and then let a co-worker borrow it. He was too cheap to use the proper oil, so he filled it with ATF. It destroyed the bar and chain in no time. I would say less than 2 maybe 3 tanks of fuel. It even messed up the oil pump, so after I replaced these 3 items, he was almost at the price of the saw when he bought it, and would have been way over if he had taken it in for labor and parts. Oil by the gallon at TSC stores go on sale for about $7. I haven't seen many brands over $9 regular price. Parts are too expensive to use anything but the real stuff I.M.H.O.
echoman is offline
post #12 of 47 Old 11-14-2011, 06:24 AM
redmule's Avatar
On using the right bar oil.
redmule is offline
post #13 of 47 Old 12-19-2012, 06:48 PM
jerry_nj's Avatar
I am tempted to start a new thread, and indeed I may....as this thread isn't an exact match from my question on "cold weather chain bar oil".
I read on a customer evaluation for my newest saw, a Husky 440I, that he uses vegetable oil, and says it is cheaper. I have a problem with both parts, but the part that says vegetable oil is better in cold (below 40 degrees F?) weather may be correct. The cost, I pay about $10 a gallon for bar oil, I think Tractor Supply has a house brand for that amount.
So, what should I use below 40 degrees, how about vegetable oil? Which doesn't pass the "sticky" requirement in my experience with vege-oil.
1989 Craftsman LT 12 HP 38" 2-blade deck - Retired
1993 Craftsman GT6000 18 HP B&S twin L-head 44" 3-blade deck, - Avatar and duty GT
2005 Craftsman DYT4000 42" 2-blade deck - B&S 18.5 Intek - new head gasket twice in 500 hr. Was hit by a Pine tree blown down by Hurricane Sandy Oct.2012. But I now have the PYT9000 and a real mowing machine
2011 Craftsman PYT9000 B&S 26 HP Professional and 46" 2-blade deck. Wife said "ANOTHER TRACTOR?"
I replied "Yep"
jerry_nj is offline
post #14 of 47 Old 12-19-2012, 07:29 PM
The Magnificent
D-Dogg's Avatar
I catch a load of crap from the guys for using plain old 30wt, Jerry.
D-Dogg is offline
post #15 of 47 Old 12-19-2012, 07:39 PM
FORD_LGT_165's Avatar
I use used oil... for people that say Used oil doesn't lubricate enough. I guess my HEMI needs bar oil instead .... Get real....
FORD_LGT_165 is offline
